Connecting Crystalsky Android tablet to BlueROV2
Hi, I am using a DJI Crystalsky monitor to control my BlueROV2.
I have a problem though, I am missing 4 buttons in Qgroundcontrol joystick setup.
All functions except gain and lights are present and working.
I am using Logitech F710 via bluetooth dongle.
My Qgroundcontrol version is 3.4.4 APK, latest.
The Crystalsky monitor is Android 5.n.n.
Can anyone help me with this problem?
Cheers, Jan R
Hi Jan,
We do not support QGC for Android devices, this problem is probably a consequence of poor drivers for joysticks in Android.
Just to make sure, can you check if all buttons appears in the joystick menu of QGC ?
If some buttons are missing from the menu, your android version does not have the necessary drivers for this joystick.
Hi Patrick,
Thanks for your reply.
All buttons on the joystick are working, I can see the buttons are reacting on Android from 5.n.n and up.
Cheers, Jan Robert
Hi Jan,
Just to make sure, how are you checking the buttons ? Are you using an app or QGC joystick configuration menu ?
Hi Patrick,
I am using QGC joystick configuration menu.
I can see and operate 10 functions. I am missing gain up/down and light up/down.
Cheers, Jan Robert
As @patrickelectric mentioned, we do not support android platforms at the moment. You may reassign functions to those buttons that are available to you, or you may put in a bug report and wait for the issue to be resolved when we do work with android.
Hi Jacob, thanks. I will reassigne the two functions.
Cheers, Jan Robert
