Compatibility of Logitech BRIO Ultra HD Pro Webcam with BlueOS
Will the current BlueOS version supports the Logitech BRIO Ultra HD Pro webcam? I need to confirm before buying one.
Hi @angelorisonk -
If the camera is a UVC device that has an H264 stream available, it will work!
No it supports raw formats only
This datasheet seems to indicate it is a UVC device, assuming it is the same model?
I do find some forum references that indicate it only supports MJPEG or YUV2 output. This should be supported on more recent versions of BlueOS, based on this thread - I’d recommend the latest, which is 1.2beta7 at the moment (or newer.)
Thank you for your response. Yes, that’s the correct specification. Is it feasible to utilize IP webcam software on a smartphone to stream video to BlueOS?
Hi Angelo -
You can add an IP camera stream in BlueOS via the “restream” option at the bottom of the Video Streams page. If you’re using QGround Control on Android or iOS you should then be able to view the stream, as well as control the vehicle. I hope that answers your question!
