This is the cheapest I have seen 5200 mah LiPo’s. Looks perfect for the T100.
Hi Richard,
Agreed. This is definitely the cheapest source. Keep in mind that each T100 should have about 15A of discharge current available for it, so if you are using 3 T100s, that’s 45A. A 5200 mAh battery with a 10C rating will have a maximum discharge of 52A, so that’s cutting it close. If you use more than 3 thrusters, I would recommend finding a battery with a higher “C” rating or larger capacity.
You probably know that but I just want to make sure!
Best,
Rusty
Rusty,
My plan is to run two 5200’s for 4 thrusters and get about an hour of underwater time, depending on the current, and how much vertical thrust I am using. I have found that 15 minutes of bottom time at a particular reef gives me about all of the copy I need to see what is going on and to make a nice brief clip.
Richard
