Hi, I’m building a three-thruster ROV with BlueRobotics products. I am using the navigator + Raspberry Pi 4B for flight control. The goal is the robot will execute some predefined patterns autonomously, such as a circle or a square. But I’m stuck at the very beginning. I cannot control the ROV with pymavlink.
I’m running the BlueOS ROS1 extension, provided in this docker container.
To communicate with the autopilot, I created a UDP client (udp:localhost:14550) from BlueOS web UI. Please see the image below. I am not sure if a new client was necessary, or I could just use the default MAVLink2Rest client (port 14000).
Then I’m trying this code from inside the Docker container:
from pymavlink import mavutil
import time
import threading
# Connect to autopilot via localhost port 14550
master = mavutil.mavlink_connection('udp:localhost:14550', source_system=250)
# Wait for heartbeat
master.wait_heartbeat() # <- I'm receiving heartbeat perfectly fine
print(f"Connected to system {master.target_system}, component {master.target_component}")
# Start heartbeat thread
def send_heartbeat():
while True:
master.mav.heartbeat_send(
mavutil.mavlink.MAV_TYPE_GCS,
mavutil.mavlink.MAV_AUTOPILOT_INVALID,
0, 0, 0
time.sleep(1)
# I did not use this thread initially,
# GPT suggested that continuous heartbeat sending is necessary.
# So I gave it a try. But no luck!
threading.Thread(target=send_heartbeat, daemon=True).start()
time.sleep(2) # Let heartbeat settle
# Set mode to MANUAL
master.set_mode('MANUAL')
time.sleep(1)
# Arm motors
master.arducopter_arm()
print("Arm command sent")
time.sleep(2)
# Check arming state
print("Motors armed?", master.motors_armed()) # <- always returns 0
# Manual Thruster Command
# Example: forward surge only
for _ in range(20): # send 20 times to keep signal alive
master.mav.manual_control_send(
master.target_system,
100, # x: forward
0, # y: lateral
500, # z: throttle (range 0-1000)
0, # r: yaw
0 # buttons
time.sleep(0.5)
print("Manual control command sent")
master.arducopter_disarm()
print("Disarm command sent")
Observation vs expectation:
I am receiving heartbeat. I am receiving all rostopics. When I send the arm command, I can see “Armed” appears on BlueOS web UI. But if I check using
master.motors_armed(), it always returns false. I expected it to be true. -
Since arming is not working, I cannot control the thrusters either. I tried both
master.command_long_send()andmaster.manual_control_send(), but don’t see any response from the thrusters.
Possible reasons:
Am I using the UDP client in the wrong way?
Is Docker creating a communication barrier and preventing the commands from reaching autopilot?
Did I miss any initial configuration?
Any help is appreciated!
Reason that I can discard:
I can arm/move the ROV with a joystick via QGroundControl. So I’m pretty sure hardware and connections are correct. It’s just some network issue that I cannot figure out.
