Camera tilt not working. gimbal type error
trying to get the gimbal working. I tested the servo with a servo tester and it works. its plugged into auxout2 on the pixhawk. when i go to the camera gimbal page this is the page i get. i cant find anything labeled gimbal type in the parameters
Hi @daveycleaning
Do you have a 5V supply plugged into the servo GPIO to power the 5V rail for your servo? That’s the most common reason that the servo doesn’t work.
Additionally, you’ll want to make sure that Servo10_Function is set to MountTilt under Autopilot Parameters (or on the Vehicle Setup GPIO page.) That relationship is detailed in the table here.
