couple questions, was out for ROVs first ocean dive and went well,
The ROV sinks slightly in salt water, should I remove ballast? And I so, how do I do this? Can’t seem to find any info on website?
Also, when descending quickly, I found the ROV would rotate and stay at a fairly sharp angle while descending, at slower decent rates it would descend fairly straight
When accelerating, the ROV pitches fairly aggressively and then levels out, I assume this is normal as I’ve experienced it with other ROVs
Lastly, I tried to calibrate the unit and it seemed to stall out and the progress bar never fully filled even though we were rotating the unit in a number of directions?
