how can I find out what button of the logitech controller has which number (0-14)? Below the bumper-buttons there are some further buttons with RT and LT written on it. Which number does they have so perhaps I can assign functions to them (for example newton gripper)?
Thanks!!
Chris
Hi Chris,
Welcome back! On QGC when setting up the joystick you have the option of using the “mode” button. When this is selected you can use this option to switch to a second configuration.
To do this, head to the joystick tab and reassign the second column to a different option. When you fly the ROV and need a second function (or extra buttons) press “mode” and these options are available.
The buttons will light up when pressed, use the drop down menu to select the button operation.
I hope this helps.
Kind regards
Depp Supplies.
thank you, I will try this out!
best regards
Chris
sorry, there is no option to use the mode-button…
I am also curious how to activate the lower bumper buttons on the Logitech. Has anyone done this?
I think these would be an additional two buttons that are not currently among the 14 options - would be quite handy!
