I have connected Raspberry pi 2 and Pixhawk(ardusub 3.4, bluerov framework), when i calibrate the joystick, i can not set the button actions. and in the flight mode, there is no “depth hold” and “munual” mode.
I am going to pay 3200 dollars for equipment whose software requires a “daily” build?!!
@qdxiatao; are you sure you loaded the ArduSub firmware on the pixhawk?
(I can’t read your first attachment as its too small)
I was recommending the “daily” build because the “stable” build does not reflect the changes required to work with the present ArduSub software. He only has to download and install the “daily” build once to be up to date.
Regards,
TCIII AVd
“Use at your own risk!”
I am periodically downloading and installing the QGC “daily” build and have had no trouble using the “daily” build with the ArduSub software on my BBBMINI.
If you persist in using the present “stable” build, you will experience what qdxiato is experiencing with his QGC “stable” build.
Regards,
TCIII AVD
I loaded the ArduSub firmware on the pixhawk. i downloaded daily build QGC, it is ok.
