Is there anyone who knows how to correctly wire the control card to make it work in QGC ?
Continuing the discussion from Using the BU0836A Joystick Controller with QGC:
What’s the problem?
FYI, You need to wire the joystick before windows detect it properly.
Cheers,
E.
Etienne, QGC did not recognize. So obviously the wiring must have been wrong (or less likely the circuit board). That is why I am asking if someone can help draw the lines where the wires should go. If the wiring is correct then the circuit board is not working
Etienne
I have now dismantled the board and will re-wire it again. But out of curiosity, should QGC recognice the the board without the joystick and buttons connected as long as it is connected with the usb?
You would think it would but it doesn’t. Wasted hours trying to understand what was wrong with the pcb until I decided to wire it and windows picked it up…
your wiring seems fine
