Brand-new Pixhawk not starting
Hi @monsterbacke,
Please try going through our troubleshooting steps, and if they don’t manage to fix the connection issue then please let us know the results from each step :slight_smile:
ArduSub by default expects a Leak Sensor to be connected to AUX port 6. That leak sensor is effectively a ‘normally closed’ switch, which becomes ‘open’ when one of the probes comes into contact with water, so if it’s not plugged in ArduSub thinks there’s a leak and engages the Leak Failsafe.
If you don’t have a leak sensor then you should be able to disable the leak sensor failsafe in QGC on the Safety Setup Page. If it’s annoying while you’re trying to get the connection working via Companion, plug the Pixhawk directly into the topside computer and turn off the failsafe before reconnecting it to Companion and continuing the troubleshooting steps :slight_smile:
While the ArduPilot docs match our behaviour for the most part, we don’t yet have proper documentation for how the various LEDs/sounds work with ArduSub. It is something that’s in the pipeline, but we unfortunately haven’t yet had the time to complete it.
