I am running this github repository GitHub - patrickelectric/bluerov_ros_playground: Scripts to help BlueRov integration with ROS from patrick
but when i run gazebo_teleop it doesnot work it gives me this error which i have put it on the bottome please can someone check why i am getting this error, moreover i am using ROS kinetic Edition and when i run the ps3 controller it doesnot work because of joy_node plzz can someone check
Do you have joy package installed with all necessary packages/dependencies ?
Try to search for joy_node or run joy package examples to find out what is going wrong.
I install this package
I tried to catkin_make in both with catkin_ws and inside bluerov_ros_playground.
But it still give me the same error. Is there any specific library which i should use for joystick drivers. I have searched alot on google but not able to resolve the issues.
Can you please explain how should i catkin_make the joystick_drivers
Thanks for replying
Enable the verbose mode do debug what is going on with gazebo
