BluePrint Lab Alpha 3 Integration
Moving this comment to its own topic.
I got a motorized arm(BluePrintLab), which has three degrees of freedom. How can I integrate it into Pixhawk?
If anyone has any way to help me, I would be very grateful
thank you
Hi @17665200818,
This post indicates that BluePrint manipulators should be compatible with the BlueROV2 companion computer, and possibly controllable from QGroundControl as well.
I had a look on their website and they don’t seem to post specifics of the API or signals used to control their manipulators, but they do mention they provide ā€œResponsive Integration Supportā€, so I’d suggest you contact them directly at info@blueprintlab.com and ask about interfacing with BlueROV electronics. They’ll no doubt be happy to help you get your manipulator up and running :slight_smile:
It would be interesting and useful if you can post a follow-up here afterwards for others looking to do something similar later on :slight_smile:
OK, I’ll have a try in the way you provide, and if there’s any progress, I’ll share it to here again,
Thank you
