I’m setting up my boat with the Basic BlueRobotics ESC paired with T200 Thruster.
Since the ESC runs the BLHeli_S firmware, which parameters I must set/define in ardurover to properly configure it? I mean parameters like MOT_PWM_TYPE, SERVO_BLH_MASK, SERVO_BLH_3DMASK, SERVO_BLH_AUTO, etc…
I haven’t used ArduRover so am not super familiar with the required parameter setup (if there is any). Our BasicESC is bidirectional, and controlled by a standard servo-style PWM signal. It doesn’t support sending telemetry about each thruster to the vehicle, so many of the SERVO_BLH_... parameters are likely unused even if they have values set.
In ArduSub 4.0.3 I have
Parameter
Value
MOT_PWM_TYPE
Normal
SERVO_BLH_DEBUG
Disabled
SERVO_BLH_MASK
0
SERVO_BLH_OTYPE
None
SERVO_BLH_POLES
14
SERVO_BLH_PORT
Console
SERVO_BLH_REMASK
0
SERVOBLH_TEST
Disabled
SERVO_BLH_TIMEOUT
0 s
SERVO_BLH_TRATE
10 Hz
If I update to the latest development version (4.2.0), I get the additional parameters
Parameter
Value
SERVO_BLH_3DMASK
0
SERVO_BLH_RVMASK
0
I presume (but can’t guarantee) that the parameters should be the same for rover
