Ardusub Version: Not found
After updating from Companion 0.0.16 on two old BR2’s:
  • No connection to QGC (video stream is connected though).
  • Pixhawk Firmware Update > ArduSub Version: Not Found
  • Active Services: mavproxy no longer listed.
Should I upload the firmware file? If so, where do I find it?
Hi, can you do a teamviewer session?
Yes I can do a Teamviewer. I’ll send you the ID and pw
@gcelec’s problem was resolved by going to http://192.168.2.2:2770/mavproxy, and clicking the ‘reset to defaults’ button.
had same problem, and this solution worked, thanks
