Can water linked underwater gps be integrated with normal ardusub rov other than bluerov2?
If it can, what is the ardusub version that supports this feature?
Hello @fred
The underwater GPS integration is done by the Companion, but if should work on any ROV running stable Ardusub with a companion.
Thank you for your replay @williangalvani
I can see the location of the ROV on the map now.
But when I set a mission and try to switch to Auto mode I receive “Unable to start mission: Vehicle failed to change to Guided mode.”
I’m using Ardusub v3.5.4 and QGC 3.5.3
