Analog Camera Add on BR2
I want to add the Analog Camera for rear facing on BR2. Assuming I will need the Fathom-S Interface boards, to run video signal only is just 1 TP required run signal between boards?
Hi Doug,
Depending on the camera/signal and tether length, you can actually connect the video feed directly to a spare twisted pair. The amount of interference will increase with tether length, but we’ve done 150m (GoPro 4 composite video) and the signal is still fine for tether management/navigation
Thanks Marcus,
I have a 200 meter tether. Will using the Fathom S Boards do what I believe is called line balancing to clean up the signal?
Also, do you know of a reference dimension for positioning the analog camera with a 3" dome?
Doug
WT Industries, LLc
Houston, Texas
832-731-7098
