Why using a DVL if I have an USBL?
Hello everyone !
I want to implement a precise positioning for my ROV. From what I have seen during my researches, the DVL and the USBL are the main sensors for this task.
But the DVL isn’t cheaper, the position calculated from it will drift and it doesn’t work well if you are too far away from the seabed.
On the other hand, the precision of the USBL seems more than acceptable (more or less few centimeters in the best cases) and its frequency of new positioning data seems enough for the models that I have seen.
So why using a DVL ?
Hi!
An USBL give you world positioning all the time, but it jumps some meters at distance.
A DVL give you very precise movements, but not world positioning.
That means that it drifts by distance/time, but also if you deploy at great depth where you have to use surface positioning as starting reference.
On work class systems you use both working together with advance calman filters.
You use USBL for estmates and averages, DVL for movements.
This gives good positioning, but complicated and expensive.
Hi Mathis
If you’d like to learn more about the differences between positioning systems like USBL, and position aiding systems like DVL, this wiki page from our website is a great start: Nortek | A Complete Guide to Underwater Navigation
One key thing to remember with USBL is that it requires continuous interaction between the ROV and a surface transponder, which can be unreliable in real world conditions, whereas DVL/INS solutions are fully self contained.
Traditional DVLs can only be used for relative velocities and must pair with an INS to give real world position, however newer models such as the Nucleus actually contain their own AHRS. In the specific case of the Nucleus, this can now be used to continuously output position, in addition to attitude, depth, altitude, water temperature and measurements of current speed.
Hello Mathis!
We’ve just posted our latest guide, A Smooth Operator’s Guide to Underwater Sonars and Acoustic Devices, which you might find useful as we dive into both USBLs and DVLs!
Thanks @nicolettep, and great to be having this discussion as I’m trying to get my head around pros/cons of various. On USBL: My understanding is that USBL transceivers have a sensing ‘cone’ that the ROV must remain within. This becomes a major limitation in shallow water applications. Correct?
Some USBLs may have a sensing ‘cone’ that the ROV should stay out of. From Cerulean Sonar’s ROVL manual:
Hi @PeterM ! The effective sensing area seems to vary between different systems. As @k.deboer mentioned, some systems have an area you should avoid, while other systems only mention line of sight.
A more common issue with USBLs in shallow waters has to do with multipath as sound can bounce off the bottom or surface which can confuse the sensor. It won’t know what path was taken, so there’s some additional uncertainty about the measurement.
Ms @nicolettep, May I please ask you to give some examples of both kinds of USBLs? I mean USBLs that have an area we should avoid and others that works line-of-sight. Are some USBLs have no angular limitation and only the ROV should be in the line-of-sight? It was the first time that faced this amazing thing. I am very interested to hear more
Hi @Eric1998 !
My last response may have been a bit confusing. USBLs need line of sight no matter what, but some do have areas that you want to avoid (as that Cerulean diagram shows for theirs). All USBLs likely have limitations, some vendors may just document them better than others.
Hi Ms @nicolettep
In the case of electromagnetic waves and the theory of antennas, there is also the matter of line-of-sight. Still, we have omnidirectional antennas, just as we have directional antennas. I mean omnidirectionality is not an advantage and ideality for an antenna. it is just a type of antenna. but as you explained it seems that this matter does not apply to USBL and this means that a USBL cannot be omnidirectional inside the water (of course 180 degrees). Why? What is the difference between sound as a wave vs electromagnetic wave? why do we have omnidirectional antennas but inside water, USBL does not propagate in all directions and has limitations?
Hi @Eric1998 !
USBL is about localization, so while the sound will bounce and reflect all around like an electromagnetic wave, we care about the shortest distance the sound travels, from beacon to USBL receiver. The time difference of arrival of the beacon’s pulse at the USBL is used to compute a range and distance between the devices.
Our group just purchased a Nortek Nucleus1000, we also have a waterlinked USBL (UGPS) system. Is there currently a way to integrate the GPS data with Nucleus’ pose output for a super accurate position?
Hi @coanderson -
If your vehicle has both the Nortek DVL and UGPS feeding velocity and position corrections into the autopilot correctly, then ArduSub will automatically fuse them for the best position estimate possible !
Oh awesome! I love it when this happens. Thanks Tony!
