Hi @Marengsen,
Our docs download link is to the latest version that’s been tagged as stable - later releases may not be stable, or may not have been tested as thoroughly. That said, it does seem like the stable tag has been lagging behind by quite a bit, so thanks for letting us know - I’ve raised this internally and we’ll likely update it soon (probably to the latest release, but possibly a slightly earlier one).
That does sound like a bug - did you also try updating using the Ping Viewer version from the website?
Note also that we’ve just released an update to the ping-arduino library (0.1.1), so that it’s now able to work properly with the 3.28_auto firmware instead of needing to downgrade it. That should be available from the Arduino library manager within a few hours, although if necessary it’s possible to install manually by downloading the release .zip and using Sketch / Include Library / Add .ZIP Library.... We’re in the process of updating the guide you were following - it should be the same other than the recommended firmware version.
Yes, it should be straight forward. Given what you’ve tried, if it’s not working that’s most likely a bug/issue in the software rather than you doing something wrong.
The log files you/we would be after are the GUI Logs. We’d definitely appreciate if you can upload one from where the update didn’t work, but beyond that you’re welcome to install the updated Arduino library and move on with what you actually wanted to do with it ![]()
It would be great if you could submit a bug report (requires a GitHub account) ![]()
If we’re unable to replicate the firmware updating issue then we might ask for your help/some more logs, but it’s mostly important that you’re not being actively held back from using the device.
