The following information may help you if you are experiencing erratic motor behavior, especially when in automatic control:
The BR ESC’s have a +/- 25 usec deadband built into the firmware. In the case of using an Adaruit Metro-Mini Arduino processor to interpret joy-stick position, the +/-25 is not enough. I suspect this may be the case for other processors as well.
My measured noise from the the A/D conversion of 0-5 volts to 0 - 1023 at the joy-stick mid-point position is 480 +/- 7. Mapping that to 1100 - 1900 gives an ESC input of 1489 - 1529 (measured), due to system noise. Even though the 1529 isn’t much outside the deadband, it is enough to cause trouble with heading-hold applications. My LSM303 has a measured variation of +/- 2 degrees. Using a Kp of 15, which seems to work best, and add to that the processor noise of above, you can see a big problem can arise. If the system happens to see a + 2 compass variation and a + 7 noise spike from the A/D converter at the same time, the ESC can receive a very large pulse width signal. It happens, and has happened to me on numerous occasions. I feel it can be damaging to the motor bearings when instantly accelerating from a dead stop to high RPM, plus it drives me crazy when trying to record video footage, or hold course when in heading hold. I can reduce the Kp, to minimize the problem, but then my heading drift increases to undesirable levels.
For non-heading hold (manual) steering it is easy to build a larger deadband into the control program to avoid erratic motor action when the joy-stick is centered. I haven’t figured out how to do that for auto heading work.
I would like to hear if any of you have worked with this issue and what solutions you came up with.
Very interesting. I glad you found this. I have a few suggestions:
As you mentioned you can add deadband to the joystick input. If you use the right range, they will always be zero at center.
Alternatively, you could apply a “exponential” curve to the input like is commonly used on RC radios for smoothly control response. The exponential response is flat near the center and strong when moved to either extreme. That would reduce the noise in the center. We’ve done this on ArduSub and it helped a lot.
You can add a software low-pass filter to the input to smooth out any spikes that might cause issues.
