I’d just like to know the BR2 Heavy version volume ? Or its buoyancy.
I just know that is weight is 11,5kg.
Thank you for your answers.
The net buoyancy is the same as a standard BlueROV2: Technical Specifications.
The special machined buoyancy blocks that come with the Heavy Kit offset the weight of the additional thrusters and other components.
Thank you for your answer.
The net buoyancy was 0,2 kg, right ?
Correct, 0.2 kg positive and properly ballasted and trimmed out. If you need additional buoyancy, we have special machined buoyancy foam blocks for the primary fairings.
Thank you for your quick answers !
