Waterlinked DVL Network Settings
I’m currently getting my waterlinked DVL going on board my blueROV. I know I need to reset the IP address of the DVL o 192.168.2.95, but what are the other correct settings? I can’t find the following in the documentation. What are they supposed to be?
Gateway = ?
DNS = ?
Hi @Jake,
If you bought your DVL through Blue Robotics then you can follow our integration guide, and it shouldn’t require network configuration unless you’re using a non-standard network on your vehicle.
Does it allow you to leave these unspecified? If not you can try 192.168.2.1 or 192.168.2.2 for both of them, but if neither of those options work then you’ll have to ask WaterLinked for further advice.
