Thanks @jwalser & @williangalvani -
Companion version Version: 0.0.21-30-g5cafdde
ArduSub Version: 4.1.0
2020-12-03 DVL.params (24.3 KB)
Still working through it, Paul. We had a faulty unit, exchanged it - apparently now we can’t get the Pi to talk to the DVL, doesn’t seem to recognise the IP address. I’m a novice, but will try and have a look this week.
Update: yup, tested fine in the water.
Fix:
The Ardusub documentation says start at builds 0.0.22 or 0.0.23 and then do the update to the DVL branch. We kept getting the Water Linked tab in the companion web interface, but we couldn’t enter an IP address for the DVL - we got the spinning wheel of despondency. In addition, we couldn’t see the DVL listed under Active Services in the System tab.
Fixed now - for other users: if you have the same problem, log onto the pi (http://192.168.2.2:8088/), navigate to \companion\services\waterlinked\dvl-a50 and run pip3 install . --user
(note the space between install and . and the space between --user, and note that it’s two minus signs before user). Let that run, reboot and fixes the problem. Kudos to @williangalvani . Hopefully it’ll get incorporated in a new build. Now to see how well the DVL works in the field.
@wlkh for info !
Hi Kristian, whilst we managed to get the DVL working on one system, we seem to be unable to replicate on other machines - I think the culprit is the companion computer software build. We followed the instructions step by step (and have tried multiple variants), but the DVL doesn’t show up under Active Services in the CC system tab, which it does in the one that’s working. We’ve used Ardusub 4.1.0 and 4.2, and various CC builds starting 18, 21, 22, 23 and latest build, adding the WL branch to each - but no combination seems to work.
Do you or @williangalvani have any suggestions, or can you tell us how you built your CC software and which Ardusub version you’re using ? (I don’t think the version of QGC makes any difference).
Thanks !
Hi @richard-rickett ,
Please check what is the Status shown in the DVL section of http://192.168.2.2:2770/waterlinked
Also, try restarting the driver in that page.
Hi Willian,
Next to DVL IP address there’s a spinning wheel, and we’re unable to enter the DVL IP address. Status is “Unable to talk to DVL Service”. Turning Driver enable on and off makes no difference, nor pressing Restart DVL Service.
Can you confirm that in the System tab, under Active Services there should be a line called “DVL-services” ?
Also - meant to mention before - the DVL is working fine, we can see it under its IP address and via waterlinked-dvl.
cheers
You are correct. The dvl service is not starting and the frontend is unable to talk to it.
IT turned out that there were some dependencies missing in his setup
This could have been due to a missing step in checking out the dvl version of companion, but can easily be fixed by running sudo python3 /home/pi/companion/services/waterlinked/dvl-a50/setup.py install
in the web terminal
@williangalvani Unable to start dvl service even after the command you refered above.
What we did is here:
We found an error message while executing the main.py:
pi@raspberrypi : ~ $ ./companion/services/waterlinked/dvl-a50/main.py
Traceback (most recent call last):
File “./companion/services/waterlinked/dvl-a50/main.py”, line 6, in
from flask import Flask
File “/usr/local/lib/python3.4/dist-packages/Flask-1.0.3-py3.4.egg/flask/init.py”, line 17, in
from werkzeug.exceptions import abort
ImportError: No module named ‘werkzeug’
And we also found an error message while executing the setup.py:
pi@raspberrypi : ~ $ sudo python3 /home/pi/companion/services/waterlinked/dvl-a50/setup.py install
running install
Checking .pth file support in /usr/local/lib/python3.4/dist-packages/
/usr/bin/python3 -E -c pass
TEST PASSED: /usr/local/lib/python3.4/dist-packages/ appears to support .pth files
running bdist_egg
running egg_info
creating dvl_service.egg-info
writing requirements to dvl_service.egg-info/requires.txt
writing dvl_service.egg-info/PKG-INFO
writing dependency_links to dvl_service.egg-info/dependency_links.txt
writing top-level names to dvl_service.egg-info/top_level.txt
writing manifest file ‘dvl_service.egg-info/SOURCES.txt’
warning: manifest_maker: standard file ‘setup.py’ not found
reading manifest file ‘dvl_service.egg-info/SOURCES.txt’
installing library code to build/bdist.linux-armv7l/egg
running install_lib
warning: install_lib: ‘build/lib’ does not exist – no Python modules to install
creating build
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying dvl_service.egg-info/PKG-INFO → build/bdist.linux-armv7l/egg/EGG-INFO
copying dvl_service.egg-info/SOURCES.txt → build/bdist.linux-armv7l/egg/EGG-INFO
copying dvl_service.egg-info/dependency_links.txt → build/bdist.linux-armv7l/egg/EGG-INFO
copying dvl_service.egg-info/requires.txt → build/bdist.linux-armv7l/egg/EGG-INFO
copying dvl_service.egg-info/top_level.txt → build/bdist.linux-armv7l/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents…
creating dist
creating ‘dist/dvl_service-0.1.0-py3.4.egg’ and adding ‘build/bdist.linux-armv7l/egg’ to it
removing ‘build/bdist.linux-armv7l/egg’ (and everything under it)
Processing dvl_service-0.1.0-py3.4.egg
Removing /usr/local/lib/python3.4/dist-packages/dvl_service-0.1.0-py3.4.egg
Copying dvl_service-0.1.0-py3.4.egg to /usr/local/lib/python3.4/dist-packages
dvl-service 0.1.0 is already the active version in easy-install.pth
Installed /usr/local/lib/python3.4/dist-packages/dvl_service-0.1.0-py3.4.egg
Processing dependencies for dvl-service==0.1.0
Searching for click>=5.1
Reading Links for click
Best match: click 8.0.0a1
Processing click-8.0.0a1.tar.gz
Writing /tmp/easy_install-vzmflol6/click-8.0.0a1/setup.cfg
Running click-8.0.0a1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-vzmflol6/click-8.0.0a1/egg-dist-tmp-o66bzzpg
no previously-included directories found matching ‘docs/_build’
warning: no previously-included files matching ‘*.pyc’ found anywhere in distribution
click 0.0.0 is already the active version in easy-install.pth
Installed /usr/local/lib/python3.4/dist-packages/click-0.0.0-py3.4.egg
error: Could not find required distribution click>=5.1
I has also met the problem. The reason is some python module has not be installed. Maybe you should Install update scripts manually.
I’m using a development version of QGC for my BR2 which is working well with the DVL A50. Where could I get this version to install on another PC?
I’m integrating a DVLA50 into a BR2 but I can’t get the vehicle to go into Position Hold mode.
I’ve previously integrated a DVLA50 with help from BR Engineers so I have a record of the settings from the vehicle it was working on and the .params file
2021-05-19 System Setup Page.pdf (65.6 KB)
. Last time it was suggested I use Ardusub version 4.1 but I can’t remember where to find it - Is there a link available?
The Companion Software Status version is currently “revert-point” - I haven’t seen this before . How could I update it to version 0.0.21-30-g5cafdde ?
Things that are working:
Pre-built ArduSub versions are available at the ArduPilot firmware site, which I got to via the ArduSub downloads page (for future reference). 4.1 is beta, so you probably want this.
I’m not certain how to cleanly install companion to a specific commit, so I’ve asked that internally and you’ll hopefully get a response soon
@EliotBR Thanks for your help. I had navigated to the beta download page but I missed the firmware-verion.txt file so I didn’t know what version it was.
My problem is that I can’t flash the Pixhawk through the System page so I had previously done it by plugging it directly into my laptop and using the Firmware Setup utility in QGC, but that will only do the latest stable release.
When I attempt a Pixhawk Firmware Update through the system page, either by clicking on Beta, or uploading ardusub.apj it fails:
Flashing Pixhawk…
Loaded firmware for 9,0, size: 845608 bytes, waiting for the bootloader…
attempting reboot on /dev/autopilot…
Timed out trying to catch bootloader!
Hi @gcelec ,
Sorry, I’ve been pretty busy. This issue should be fixed on companion 0.0.26. unfortunately the dvl branch doesn’ t contain these changes yet. We’ll try to rebase the dvl branch early next week.
To get Ardusub 4.1, clicking the “beta” button in companion or qgc (if plugged directly to the pixhawk via usb) should do.
We have a dvl section in ardusub.com with instructions. Please let us know if you run into issues following those, so we can fix the docs .
Hi @williangalvani - no worries - I know how busy things get and appreciate your help. Here’s what I’ve done this morning:
Flashed a new microSD with ArduSub.
Went to http://192.168.2.2:2770/mavproxy > Restore Default Options, so I could see the Ardusub version.
Installed ArdSub Beta 4.1.0
Installed Companion v0.0.22 as per Water Linked’s BR2 integration instructions then updated to 0.0.24-14-gd62f472
Now Companion doesn’t recognize the DVL at http://192.168.2.2:2770/waterlinked and it’s not listed as an active service ( I did have those previously).
DVL IP address settings are the same as previously.
I have the same issue installing it from git. Orientation buttons and nothing works. Im
Im updated it from 0.0.28 → DVL
Ardusube 4.1.0 beta.
I have also tried to downgrade to 0.0.23 with same result.
Get this error when i try to start it manualy
pi@rov:~ $ ./companion/services/waterlinked/dvl-a50/main.py
File “./companion/services/waterlinked/dvl-a50/main.py”, line 7, in
from dvl import DvlDriver
File “/home/pi/companion/services/waterlinked/dvl-a50/dvl.py”, line 6, in
from mavlink2resthelper import Mavlink2RestHelper
File “/home/pi/companion/services/waterlinked/dvl-a50/mavlink2resthelper.py”, line 1, in
from companionhelper import request, post
File “/home/pi/companion/services/waterlinked/dvl-a50/companionhelper.py”, line 2, in
import requests
ModuleNotFoundError: No module named ‘requests’
