Mavproxy starts on the Pi automatically at boot. If you try to start mavproxy, then you have two programs connected to the same serial port, and you will get garbage. You either need to resume the existing session: screen -r mavproxy
or stop the existing session: screen -XS mavproxy quit
You can modify ~/companion/.companion.rc to prevent mavproxy from starting at boot.
the console says âwaiting for heartbeat from /dev/ttyAMA0â and starts showing some garbage and it continues showing until ctrl-C is pressed.
I need some help on this. What might be the issue and possible solution?
Hi Jacob. Thanks for the reply. I am dying to solve the multiple issues am facing with my flight controller and Rpi, so I guess without realizing I am trying to seek help from everywhere.
Hi Jacob. I follow the step, and it seems that there are no problem. But when the last step, connect to mission planner, it just didnât work. I can use my computer to that the pixhawk make a bi bi ~sound, but i just canât connect to the mission planner
when i use QGC I still canât find the raspberry pi, but when i enter âarm throttleâ on the ssh, pixhawk will make a sound.
Did that appear that I do connect the pixhawk and the raspberry pi, but canât open the ground station?
Try ls /home/pi/companion/scripts/, this will show all scripts, if start_mavproxy_telem_splitter.sh is not available, try to update your companion image via http://192.168.2.2:2770/system or flashing the raspberry sdcard as described here.
dear DsWang ; actually I have same issues as yours where I connect raspberry PI Zero with pixhawk ,pixhawk with Arducopter 3.2.1 ,i try to follow the discussion you did ,but i did not sort out the problem ,please anyone can help me to fix it
Probably you are using the incorrect serial port, you can try to find with more friendly name under ls /dev/input/by-id or with dmesg -w.
# My dmesg output
[168177.900273] usb 1-2.1.4: new full-speed USB device number 69 using xhci_hcd
[168178.174755] usb 1-2.1.4: New USB device found, idVendor=26ac, idProduct=0011, bcdDevice= 1.01
[168178.174757] usb 1-2.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[168178.174758] usb 1-2.1.4: Product: PX4 FMU v2.x
[168178.174759] usb 1-2.1.4: Manufacturer: 3D Robotics
[168178.174760] usb 1-2.1.4: SerialNumber: 0
[168178.183552] cdc_acm 1-2.1.4:1.0: ttyACM0: USB ACM device
You can see that the device was named to ttyACM0, and I can use this name to connect with it.
mavproxy.py --master=/dev/ttyACM0
WARNING: You should uninstall ModemManager as it conflicts with APM and Pixhawk
Connect /dev/ttyACM0 source_system=255
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from /dev/ttyACM0
Lights1LiIMAV> online system 1
MANUAL> Mode MANUAL
QAPM: ArduSub V3.5.3 (ad81760b)
APM: PX4: 8d505a02 NuttX: 1a99ba58
APM: PX4v2 003B001D 33375110 37353832
Received 689 parameters
Saved 689 parameters to mav.parm
Hello Jacob ,firstly let me thank you for yours quick response to my previous post ,you answers for sure helped me to go further to my project, today also has a problem about the result i get ,instead of get the same result which is similar to the others ,I got those number you can see it on my attached picture , could you help me to figure out it ?
