We have a problem connecting two Alpha arms to a BlueROV2. We followed the following instruction.
[ Advanced Usage | ArduSub ]
Process of setting
①Change BlueOS to Pirate mode
②Select Bridges
③Set Serail-UDP
④Left arm:
Serial port: /dev/ttyUSB0,
Serial baudrate: 115200
IP address: 0.0.0.0
UDP port: 6789
Right arm:
Serial port: /dev/ttyUSB1,
IP address: 0.0.0.0
UDP port: 2345
⑤two Serial-UDP bridges are set
We confirmed the network connection from our PC (192.168.2.2:2345 / 6789)
(!)When we reboot the system, we can see the Serial-UDP bridge setting on the menu window but we lose the network access. After deleting the Serial-UDP bridge setting and resetting the Serial-UDP bridge setting again, the network connection is recovered.
Let us know how to fix this problem.
