Trouble compiling ArduSub
Hi, I am trying to compile Ardusub, however when I try entering the make command, I get the error:
No such file or directory
make: *** No rule to make target ‘ardupilot/modules/uavcan/libuavcan/include.mk’.
Thanks for your help.
git submodule update --init --recursive
@jwalser, that worked however now when I compile I am told to:
Blockquote
On MacOS please run:
sudo pip install empy catkin_pkg
Blockquote
However, when I do this I get the error:
Blockquote
Could not fetch URL https://pypi.python.org/simple/empy/: There was a problem confirming the ssl certificate: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:645) - skipping
Could not find a version that satisfies the requirement empy (from versions: )
No matching distribution found for empy
Blockquote
Hi Reza,
This is a pip issue, apparently you are using a old version, please update.
From python:
The rolling brownouts are finished, and TLSv1.0 and TLSv1.1 have been disabled.
info.
I am now getting this error
error: this statement may fall through [-Werror=implicit-fallthrough=] if (AP_RangeFinder_NMEA::detect(serial_manager, serial_instance)) {
Thank you for all your help so far.
Hi Reza,
Can you say what are you doing and where are you getting this instructions ?
Hi I am using the command:
make px4-v2
I am following the instructions from the ArduSub GitBook
Thanks @reza, try the instructions again, I’ve added some steps.
@jwalser thank you for all your help, but I am still having issues. I now receive this error when running the make px4-v2 command.
    ardupilot/modules/PX4Firmware/Build/px4io-v1_default.build/nuttx-export/include/stdio.h:145:8: error: declaration of 'int vsscanf(char*, const char*, va_list)' conflicts with built-in declaration 'int vsscanf(const char*, const char*, __va_list)' [-Werror=builtin-declaration-mismatch]
 int    vsscanf(char *buf, const char *s, va_list ap);
compilation terminated due to -Wfatal-errors.
cc1plus: all warnings being treated as errors
What operating system and compiler are you using? It looks like something is broken with your toolchain installation.
OSX, and terminal. I think I will use something else, however.
Hi Reza,
You need to use a compatible compiler version, right now the standard version is gcc 4.9.
Can you say what are you using and version ?
Try showing us the output of arm-none-eabi-gcc -v
    Using built-in specs.
COLLECT_GCC=arm-none-eabi-gcc
COLLECT_LTO_WRAPPER=/usr/local/Caskroom/gcc-arm-embedded/7-2017-q4-major/gcc-arm-none-eabi-7-2017-q4-major/bin/../lib/gcc/arm-none-eabi/7.2.1/lto-wrapper
Target: arm-none-eabi
Configured with: /Users/build/work/GCC-7-build/src/gcc/configure --target=arm-none-eabi --prefix=/Users/build/work/GCC-7-build/install-native --libexecdir=/Users/build/work/GCC-7-build/install-native/lib --infodir=/Users/build/work/GCC-7-build/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/Users/build/work/GCC-7-build/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/Users/build/work/GCC-7-build/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/Users/build/work/GCC-7-build/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/Users/build/work/GCC-7-build/install-native/arm-none-eabi --build=x86_64-apple-darwin10 --host=x86_64-apple-darwin10 --with-gmp=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-mpfr=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-mpc=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-isl=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-libelf=/Users/build/work/GCC-7-build/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-lstdc++ -lm' --with-pkgversion='GNU Tools for Arm Embedded Processors 7-2017-q4-major' --with-multilib-list=rmprofile
Thread model: single
gcc version 7.2.1 20170904 (release) [ARM/embedded-7-branch revision 255204] (GNU Tools for Arm Embedded Processors 7-2017-q4-major)
Thank you so much for all your help
You should have downloaded arm gcc 4.9. Did you follow the instructions here?
http://ardupilot.org/dev/docs/building-setup-mac.html
Yes, I have
Hi Reza,
Can you install gcc-arm-none-eabi-49 and try again ?
That did the trick! Thank you for you continued help!
Sorry, one last question. I’ve made a custom motor layout. How do I select it in QGroundControl, as the option does not seem to show up for it.
