We are seeing significant cracking on the metallic cylindrical core/housing of our T200 thruster, as shown in the attached photos.
The concerning part is the service life. The thrusters have been in use for approximately 6 months, but they have not been operated continuously. We have conducted only a few ROV trials each month, so the actual operating hours are relatively low.
The cracks appear to have developed progressively around the cylindrical section and are now clearly visible.
Our main questions are:
Is this type of cracking a known failure mode for the T200?
What are the most likely causes of this kind of cracking — for example, corrosion, thermal cycling, mechanical stress, overloading, water ingress, material degradation, or another issue?
What service life would normally be expected for this part under intermittent ROV use?
Could operating the T200 at higher voltage/current or repeated start/stop cycles contribute to this type of damage?
Is the thruster still considered safe to operate when cracks like these are present, or should it be replaced immediately?
Is there a recommended inspection, maintenance, or storage procedure that could prevent this from happening?
We would particularly appreciate input from Blue Robotics on whether this condition is expected, and whether there is a known root cause or recommended corrective action.
We can provide additional information such as operating voltage, current, approximate operating hours, water conditions, number of cycles, and test conditions if required.
Our Operating condition: operating at 16.5V
Photos of the cracked T200 are attached for reference.
Sorry to hear you’ve run into an issue with one of our thrusters. I’d recommend reading through this post, as I believe it answers most (if not all) of your questions.
Feel free to follow up afterwards if there’s anything that’s still unclear!
We are operating the thrusters at a temperature of around 25°C, while the surrounding ambient temperature does not exceed 30°C. Under these conditions, we do not see any apparent reason for the cores to crack or become damaged.
We suspect that multiple units may be experiencing the same issue, as we have observed similar damage in several cores. We would like to understand the possible cause of this failure and request replacements for the damaged units.
Could you please guide us on the next steps and advise us on how to proceed with the replacement process?
As some other potential causes you may be operating at heavy thrust levels over long periods, and/or outside the rated voltage, and/or in sediment-rich water (especially without thoroughly flushing the thrusters with clean/fresh water after operating in sedimentary conditions).
@EliotBR We are operating the thrusters at approximately 16.5V, which is within the specified operating voltage range. Our typical operating duration is only around 30–40 minutes per session, and the surrounding water is clean swimming pool water, with no sediment or debris. Therefore, we believe that excessive operating duration, overvoltage, or sediment exposure is unlikely to be the cause of the stator core cracking. Could you please advise us on what might be causing this issue and guide us on the next steps?
Hi @uday5 -
If it is in a pool, how high are the chlorine levels?
Thermal cycling is likely the root cause for your failed stators. Are you operating the thrusters on a BlueROV2 or another vehicle? What power levels are you typically operating at? Is the 16.5 volts you’re operating at coming from a battery or some power over tether system?
