Premature Corrosion/Damage on Blue Robotics T200 Motor Core in Bengaluru, India
Hello Blue Robotics Team,
I am using a Blue Robotics T200 thruster for a robotics application in Bengaluru, India, and I have noticed significant corrosion and deterioration on the motor core, as shown in the attached photographs.
What concerns me is that this damage has occurred despite the unit being used under normal local ambient conditions. I was expecting better long-term durability from the protective coatings used in the T200, particularly when operating within the recommended conditions.
I understand that the T200 uses a flooded motor design and relies on protective coatings to resist corrosion. However, the extent of the deterioration visible in these photographs raises concerns about the durability of the core and its protective coating.
I would appreciate your technical advice on the following points:
Root cause: What could cause this level of corrosion or deterioration on the T200 motor core? Could it be related to coating failure, moisture exposure, temperature, manufacturing defects, or another factor?
Expected durability: Is this level of deterioration normal for a T200 under the operating conditions described, or could it indicate a premature failure or a defective component?
Preventive maintenance: What specific maintenance procedures would you recommend to prevent or minimize this damage? Are there recommended cleaning, drying, inspection, or storage procedures?
Repair options: Can the affected core be safely cleaned and restored, or does it require replacement? If recoating is possible, what material and procedure would you recommend?
Product improvements: Are there any known design revisions or updated components that improve the corrosion resistance and durability of the T200 motor core?
Warranty and support: If this damage is premature and the thruster has been operated within the recommended limits, would it qualify for inspection, replacement, or warranty support?
I am sharing these photographs to help identify the problem. I would appreciate a technical explanation of the likely cause and recommendations for preventing similar damage to my other thrusters.
Thank you for your support. I look forward to your guidance.
