Hi @AnkitPandia, sorry to hear you’ve had an issue with one of our thrusters.
Our Thruster Usage Guide includes guidance on disassembly and reassembly, and our T200 spare components product allows buying a replacement core, which includes the stator.
Cracked stators generally need to be replaced (rather than repairing with a marine epoxy), as the stator windings will corrode if exposed to salty water (which is not reversible), and any potential patch-ups would need to be smooth with the existing stator surface to avoid rubbing against the rotor during operation.
If a thruster fails while you are operating within the rated conditions, please let us know, so we can help resolve the issue (potentially sending a relevant replacement if the failure was within the rated operating conditions), and so we can track how and where our products fail, to identify issues in our manufacturing lines, and/or improve the product design in future iterations.
Per the Technical Details section on the T200 product page, 16.5V should be fine, and at that voltage the thruster will not draw more than 30A of current. There may be some concern with your ESC overheating if used continuously without sufficient heat dissipation, but that kind of effect is not captured in power specifications.
Stress fractures and crack propagation are likely the main relevant considerations here, and we provide guidance on care and maintenance, especially with respect to abrasive and corrosive operating conditions.
There is some extra information on longevity and usage in the FAQs on the product page
Beyond that, as Tony mentioned, operating at high current in very hot or cold water can increase the material stresses, especially if there are frequent and rapid cycles between temperatures. If you happen to be in extreme conditions it may be worth having some kind of staging, with the vehicle resting in water before and/or after a dive to slow down the temperature transitions (as has been previously described by a forum user).
Per the revision history on the T200 product page (in the Technical Details section), the only relevant stator change was in 2019:
We do not have any technical bulletins related to T200 stator cracking, so outside of the design change I don’t believe there are any batch-specific issues to be aware of.
See the response to 4.
Vibrations are always a possible contributor to stress, although a plastic frame in water tends to absorb a fair amount of vibration energy, so this is not something we’ve identified as a point of concern. If your custom frame is metal and you’ve strongly screwed the thruster to it then vibrations may be more significant, but even then if it’s significant enough to be a problem it seems more likely that would cause cracks to the stator base rather than the stator itself.
See the response to 2.
