SubseaLED - 1500W Power Supply System
Dear BlueRobotics Community,
We are set to introduce our new BlueROV2 Power Supply Unit (PSU) from SubseaLED this October. This development aims to optimize the operational efficiency and safety of the BlueROV2 system.
Surface Power Supply Unit (SPSU):
  • Safety Features: Integrated with Line Insulation Monitor (LIM), Current and Voltage Monitors, and protections against overcurrent and overvoltage.
  • Input Compatibility: Accepts a wide input voltage range (110 to 220 VAC) and is functional with both 50 and 60 Hz frequencies.
  • Power Output: Equipped with STEP-UP Switching Power Supply with an output of 600Vdc @ 3A (1800W).
  • Design Efficiency: Housed within a compact 3 Rack unit box, maximizing portability and space efficiency.
  • Connectivity: Features integrated Fathom-x with USB B connector and a reliable 7-pin surface tether connector.
Tether System BR-002:
  • Surface End: Equipped with a durable 7-pin connector.
  • Tether Characteristics: Features 8.8 mm diameter, neutral buoyancy in saltwater, 80kg working load, construction with Aramide fibers, low bend radius (90mm), water block filler, two power conductors a STP for data transmission, ground and CP reference.
  • Subsea End: Incorporates an Aramide puller, 3-pin MCIL3 BIRNS Aquamate data connector, and a 3-pin PLA3F CRE Marine metal shell power connector.
Vehicle Power Supply Unit (VPSU):
  • Input Flexibility: Supports input range between 300 to 700 VDC, enabling operations up to 450 meters with a copper tether and over 1000 meters with a fiber setup.
  • Output Capability: Provides 14 VDC at 107 Amps.
  • Thermal Management: Developed with an advanced heat dissipation design.
  • Mechanical Features: Weighs 2.4kg in air and 0.4kg submerged in Fresh Water, enclosed within the standard BR 3” 300mm enclosure and equipped with a BR pressure relief valve.
  • Safety Mechanisms: Integrates overcurrent, under-voltage, over-voltage, short circuit, and thermal protection features.
Thermal image - Side view of the BR2 after 30mins Wet test at 100% Gain.
Vehicle Power Supply Unit - Inside view
Video - Wet Test from 25% to 100%
Given its power specifications, this system is compatible with the Standard BR2, the Heavy-Duty configuration featuring 8 x T200 thrusters, as well as custom vehicles outfitted with T500 Thrusters.
We invite any questions, insights, or feedback regarding the technical aspects and potential applications of our new PSU and look forward to your valuable input as we approach the launch.
Best regards,
The SubseaLED Team
We’re pleased to official launch the BlueROV2 Power Supply Unit.
This PSU system is designed to enhance the capabilities of your BlueROV2, providing reliable and efficient power for extended underwater operations.
:battery: Features of the BlueROV2 PSU:
• High-capacity, consistent power output
• Engineered for easy integration and long-lasting durability
• Safe and efficient operation, tailored for underwater environments
:movie_camera: Explore the PSU in Action:
Discover the full potential of our Power Supply Unit in our detailed video presentation.
:arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down::arrow_down:
Watch the video to see how our PSU can transform your underwater activities.
:globe_with_meridians: More details available on our website: www.subsealed.com
:e-mail: For inquiries: info@subsealed.com
Enhance your underwater exploration with the BlueROV2 Power Supply Unit from SubseaLED.
We tested the BlueROV2 equipped with the SubseaLED 1500W power supply system! We’ve submerged it in a water tank and monitored the voltage and current as we ramp up the power from 25% to 100% gain.
The results? Impressive voltage stability even as the load increases. Check out our video.
Many have faced bandwidth limitations with competitive PSU systems, but our solution changes the game.
With our Power Supply System at full throttle on the Blue Robotics BlueROV2, and even with a Ping360 sonar connected, we achieve over 70 Mbit of remaining bandwidth across a 250m tether - proving high performance without compromise.
Quick recap:
1500W Output: Powers your BlueROV2 efficiently.
Over 70 Mbit Bandwidth: Maintains superior communication, even with sonar and other optional tools installed.
Up to 450meters Tether: Long-distance operation without losing signal integrity.
Test in sea water :ocean:
Compatibility with the Fathom-X passed :white_check_mark:
Achieving a bitrate of over 70Mbit over 250meters of tether.
https://youtu.be/XNXv-bsqhnI?si=BV-7EG4udEvocbOQ
I am currently working on developing a power architecture for a 2KM long tether ROV…My Maximum load requirements are 4000W and i assume a 700V 5.71 A transmission is a option for reducing the Cable size…Do you have any such SMPS or can you suggest me some options to achieve this
The 1500W Power Supply System in action :clapper:
This is the power it can supply when equipped onboard the Bluerov2 in Heavy Configuration.
In my humble opinion, after having used this power supply in two offshore oil campaigns, where reliability, resistance, and power are a must have, having in the past tried other similar systems recommended by B Robotics, I tell you that with this system a small Rov with a lot of potential has been transformed into a large Rov that can also face demanding work dives in the Atlantic Ocean… and there is another thing to consider and not a small one, the owners of the subsea led company having great offshore experience, are very collaborative even for particular needs they are able to give additional solutions to their system, as in the case in which in the last job I asked them for support to manage a tool that I had to mount on the Blue Rov…
@Framau thanks for sharing your insights. We’re really happy to see our system support your offshore operations!
today we did the 100th dive, with your system, even the tether is resisting quite serious daily abuse! :sweat_smile: Keeping in mind that the first dives were done in freeswim from a rig, where the launch point was 38 meters from the surface… And here the marine groove is really merciless (west africa congo)…
Very happy with the system, as you know we already bought others 2, and the second one for our ops in :congo_brazzaville:, just finally arrived today!
It’s great to see that our Power Supply System is now part of the Bluerobotics Ecosystem! :call_me_hand:
