Severed Wired on Sensor - suggestions
We have a broken wire on the Bar30 sensor. Any suggestions for repair? It is very close to the sensor.
Hi @kchassereau -
Welcome to the forums!
Sorry for the issue! That looks a bit tricky to fix, but not impossible. If you can strip the ends of the wire a tiny bit, slide some heat-shrink on the free end, and then solder the ends together, you can then protect the repair with the heat-shrink. Liquid electrical tape is a good alternative to the heat-shrink for this too, but not quite as robust.
