here is what i have in my head.
Rasp Pi and IP Camera → Network Switch → ROV Side Fathom X → Topside Fathom X → Network Switch → TP Link Nano Router → wireless connect to the computer
will this set up work?
i’m using a switch on the topside because i want to attach Ethernet cable to it if i want to.
i am attaching a router to the topside network switch because i want to be able to connect to my control box wireless.
in the event that the router does not work, at least i would have the topside network switch to connect to.
is it possible to use the TP link router as an access point for the topside network switch?
Thank you so much for your help and if you can check out my other post that would be great. i have a lot of question about this very topic and i’m pretty desperate for help
