SeaView Announces Multi-Battery Manager for Combining Multiple BlueROV2 Batteries
SeaView Systems MBM-150 Multi-Battery Manager enables two or more Lithium-ion batteries (BATTERY-LI-4S-18AH-R3-RP) to be safely combined to extend BlueROV2 operational time. This can be used with hybrid and multi-battery systems. Power is drawn from the source with the largest voltage until both/all batteries equalize. A recent post described a successful application using seven MBM-150s to complete a 5.5 hour inspection. Available directly from SeaView Systems or amazon.
2 drawings
We finished another field test and couldn’t be happier with our MBM-150. It was used to successfully complete an 800m tunnel inspection (with sonar) a few weeks ago. The Multi Battery Manager enabled dual batteries and a custom telemetry system using a 1km Fathom Slim Tether managed to get both HD video and scanning sonar data.
you used 1km fathom slim? Nice, what sort of data rate were you getting?
edit: just reread, you used a custom telemetry system, keen to hear more if you can share.
Cheers
It was a modified VDSL2 modem with additional noise filtering and low noise power supply. If I recall, our datarate was around 8Mbps with 1km of tether.
When will this be available again at either the amazon store or online
Greetings Jim,
Apologies for the delayed response.
We are no longer selling through Amazon, but you can order the MBM-150 directly from us. Please use the online quote request form here:
https://www.seaviewsystems.com/products/blue-robotics-bluerov2-and-accessories/multi-battery-manager/
Or you can send any order requests, quote inquiries, or other questions to info@seaviewsystems.com.
Thanks and Happy New Year,
Brian
Brian Tobin
SeaView Systems Inc.
(734) 426-8978
Are these still available? All links are dead
@gcelec Hello Brian,
Just want to confirm is it still available to order from you?
If no any recommendation on alternatives I can look for for reliable multiple BMS or any chance we can have possibility to look at the schematics of MBM-150 if possible. Thank you.
@nurjan14 I had email from them saying that it was discontinued
