Hi all,
I’ve got a couple of videos showing in Cockpit that it says it is unable to process, and do not show in the video folder. Has anyone found a way to recover these? They’re rather important…
Hi all,
Hi @RickMoss1 -
Do you have any files in a “temporary-video-chunks” in the same directory as the video folder? If so, @rafael.lehmkuhl may be able to advise on how to check if the recordings are recoverable.
Can you share what version of Cockpit and BlueOS you were using when these recordings were made?
Thanks Tony.
Indeed, there’s 11.4GB of files in Temporary Video Chunks…
Cockpit 1.12.2 and the latest BlueOS also.
Thanks in advance
@rafael.lehmkuhl , do you have any input on this by any chance?
Many thanks
Hey @RickMoss1! Sorry for not answering earlier. Lost this one in my inbox.
I’m working on a dedicated tool to help with that. It’s mostly working already, although it has some caveats so I decided not to publish yet.
Could you share the video chunks with me so I can test them with this tool and see if it works with them? If possible, you can send them to my email. If you prefer not to share them for confidentiality or any other reason, just let me know and I can deploy the current working version of my tool so you can test it with your video chunk files.
Hi @tony-white. I have a technician on a job right now experiencing the same issue. I think he’s running
BlueOS: 1.4.0
Cockpit: 1.15.1
Arduasub: 4.5.3
Is there ever a tool around to recover videos from the Temp Video Chunk folder?
What is causing this and what do we need to do to ensure videos are processed uncorrupted?
Thanks in advance.
Josh
Hey @VisionSubsea!
Are you running the standalone/desktop version? If so, there’s a WIP tool I was working on to process those cases. You can try it here.
You just need to access that page, click the “browse” button, go to the chunk folder (/cockpit/video/temporary-video-chunks, select all chunks (you can press CTRL/CMD+A to do that) and them click the “process all” button.
Once that is done, all the recording should be there intact. If they are not, please let me know and we can arrange a meeting so I can help you directly. All your video data is probably there, as we don’t remove it if the processing was not completed.
Hi @rafael.lehmkuhl -
Thanks for sending the details! We appreciate the access to the tool. We ended up re-doing the inspection passes and keeping our video capture clips to under 10 min of recording time. We had no issue with Cockpit processing with the associated file size.
We’ll check back for an update in BlueOS/Cockpit that resolves the issue! Or any other instruction regarding recording process in Cockpit that mitigates the potential for the incomplete videos.
We’re very impressed with the platform overall, so there is no doubt that we’ll see a resolution to the bug. Thanks again and if you need me to test or check anything during the process please send us a PM.
Thanks,
Josh
Thanks for the feedback @VisionSubsea! We really appreciate it.
We are doing some recording tasks and will get back here when we get more results.
Hi Rafael
I’m also experiencing the same issues as mentioned above.
Received the processing tool BR support, tried it but only getting up to 60% then it fails.
Using the standalone version of Cockpit. with 1.4.2 BlueOS. the recording must be around 45-50mins in duration. 2.7G of files within the folder, just no end viewable video. had other videos fail in the last 3 days, but they’re aren’t as important as this footage.
Assistance greatly appreciated
Kind regards Colin
Hey @Seair!
Just to make sure, is this the same you got to process in batches with the online tool, or its another one?
Passing here to give an update about the current state of video recording with Cockpit.
Today we recommend you to do two things:
I personally prefer to have both recordings going on, as the vehicle one can save you in cases where you lose connection to the vehicle or have a degraded connection, while the topside one save you in case you lose your vehicle.
@RickMoss1 @VisionSubsea @Seair passing here to inform that we just released Cockpit 1.17.0 and it should completely solve the problems with long recordings. You can now record for as long as you want, on any camera, without memory constraints, and directly to an .mp4 file (so it’s always playable, even while the the recording is still going on).
To benefit from all of this you’ll need to use the Standalone version of Cockpit (the desktop one, that you download and install). The Web version has been renamed to Cockpit Lite, and can now only record videos - not process or replay them.
We invite you to give it a try and let us know how it goes ![]()
I set a timer for 10 mins and restart the video recording so that the files sizes are between 1 & 2 Gb and aren’t too cumbersome. A two hour, 60Gb file is difficult to transfer and share and I’m also scared the file could be corrupted.
I would find it useful if Cockpit did have the feature of being able to set a time limit or file size limit for the video files.
Hi @gcelec! Could you open an issue in our repository with the details on this feature request? This way we can expand the discussion around it and you can keep track on its implementation.
