Hello Blue Robotics community,
I am currently working on an ROV system and plan to use several acoustic sensors, including:
- WaterLinked DVL A50
- Ping Sonar
- Ping360
- M1200D multibeam sonar
- Side-scan sonar
- Other underwater acoustic sensors
I would like to ask for advice from users who have experience operating multiple sonar devices on an ROV.
1. Dry testing before deployment
For initial testing, I would like to verify that the devices can power on, communicate with the computer, and be detected by the corresponding software before putting them into the water.
Is it generally safe to power and communicate with these devices while they are completely out of the water?
Are there any devices that must not be operated in air, or that should only be powered for a short period during dry testing?
For example, I found a Blue Robotics forum discussion indicating that the Ping360 can be operated on a bench in air for testing, although the sonar measurements themselves may not be meaningful in air. (Blue Robotics Community Forums)
For the WaterLinked A50, I also found information that it has thermal protection, but continuous operation with the acoustic sensors enabled is preferably done underwater because the water provides cooling. (Blue Robotics Community Forums)
2. Powering the sensors before putting the ROV into the water
This is the part I am particularly unsure about.
If the ROV is powered by a battery inside the watertight enclosure, I assume the battery needs to be connected and the electronics powered before the ROV is submerged.
However, I am concerned about the correct procedure:
Should I:
- Connect the battery while the ROV is on the surface.
- Turn on the ROV and allow the computers/sonars to boot.
- Verify that all devices are detected and communicating.
- Then place the ROV into the water.
Or is there a recommended procedure where the sonar devices remain powered off until the ROV is already underwater?
I am particularly interested in the recommended procedure for the DVL A50, because it appears to have different thermal considerations compared with conventional imaging sonars.
3. What about the Ping360 and other sonars?
For the Ping360, I found that Blue Robotics users have successfully performed bench testing with a DC power supply before putting the sonar in water. (Blue Robotics Community Forums)
However, I would like to know whether there are any best practices regarding:
- Powering the sonar before immersion
- Starting the sonar before or after immersion
- Operating continuously in air
- Whether the transducer needs to be submerged before enabling acoustic transmission
- Whether there is any risk of overheating during dry operation
4. Multiple sonar devices operating simultaneously
If an ROV has several acoustic sensors operating at the same time, such as:
DVL A50 + Ping Sonar + Ping360 + M1200D + Side-scan sonar
are there recommended procedures for powering them up and shutting them down?
I am also interested in whether there are potential issues with:
- Acoustic interference between different sonars
- Electrical noise
- Power supply voltage/current transients
- Ethernet/serial communication
- Starting multiple sonars simultaneously
For example, I understand that the A50 can have a relatively high short-duration startup power requirement compared with its normal continuous consumption. (Blue Robotics Community Forums)
5. Recommended operating procedure
If anyone has experience with a similar ROV setup, I would really appreciate a practical procedure such as:
Before deployment → Power-on → Dry communication test → Enter water → Enable sonar → Operation → Recovery → Power-off
It would be especially useful to know which sensors can safely be tested in air and which ones should be submerged before continuous operation.
Thank you very much for any advice or recommendations!
