Is it possible to read Tetherturns via pymavlink or mavlink2rest ?
Hi @arend,
Try this:
from pymavlink import mavutil
# Create the connection
master = mavutil.mavlink_connection('udpin:0.0.0.0:14550')
# Wait a heartbeat before sending commands
master.wait_heartbeat()
while True:
msg = master.recv_match()
if not msg:
continue
if msg.get_type() == 'NAMED_VALUE_FLOAT':
if msg.name == "TetherTrn":
print("Tether turns: %s" % msg.value)
Hi @arend,
Just a reminder that is also possible to fetch the value using mavlink2rest via the websocket feature:
You can use as argument --url http://192.168.2.2:4777/ws/mavlink\?filter\=NAMED_VALUE_FLOAT
Thank you very much for the replay
@patrickelectric and @williangalvani
Hi @patrickelectric ,
Sorry for the late replay.
When i try to fetch data i get:
aiohttp.client_exceptions.WSServerHandshakeError: 404, message=‘Invalid response status’, url=URL(‘http://0.0.0.0:4777/ws/mavlink?filter=.*’)
Unclosed client session
This happen when i try to run the example as well. Is there anything else i need to do before i can run a websocket request ?
I believe you need to get a newer version of mavlink2rest. Download it here and replace the mavlink2rest file at ~/companion/tools/. Remember to make it executable (chmod +x).
@williangalvani is correct, you should have mavlink2rest 0.9.0+ version, also make sure to have the latest companion version available running.
Thank you very much ![]()
