QGC does not connect to Raspberry Pi Companion Computer
We flashed the ardusub raspbian image on to the raspberry pi, however we found the IP address on the pi to be 169.254.144.82 ( Subnet mask 255.255.0.0) which is different from the manual IP: 192.168.2.2 ( Subnet mask 255.255.255.0).
We tried to change the surface computer IP to 169.254.144.81 ( Subnet mask 255.255.0.0) to match the Pi, but QGC cannot detect the Pixhawk.
Hi Samuel,
have you followed the network-setup and flashed the last version of companion ?
Reinstalled companion and solved the issue, thanks
