Hello guys,
I apllied pymavlink directly in RPI recently and I succeed in
master.mav.manual_control_send(
master.target_system,
100,
0,
0,
0,
buttons)
to control x input.
However, when I do this, the parameters of y, z, r are changed as well.
I check the code instruction:
X-axis, normalized to the range [-1000,1000]. A value of INT16_MAX indicates that this axis is invalid
I tried INT16_MAX but it is not defined.
I check the value of INT16_MAX in file
modules\PX4Firmware\Build\px4fmu-v2_APM.build\nuttx-export\include\stdint.h:
63: #define INT16_MAX 32767
I applied 32767 in x but the motor worked as max power.
How can I modified only one axe use this manual_control_send command?
Any help will be grateful. Thanks!
sincerely,
gtl
