Hi im kind of a newbie to the whole configuring of the Raspberry and using shell.
Anyway im setting up the ROV APM with the setup guide:
git clone -b br-ros-rov https://github.com/bluerobotics/ardupilot.git
<span class="pl-c1">cd</span> ardupilot/APMrover2
make configure
<span class="pl-c"># gedit ../config.mk&</span>
<span class="pl-c"># sudo apt-get install gawk</span>
make
make upload
But when i type “make” i get the error:
../mk/find_arduino.mk:45:***ERROR: cannot find arduino on this system, please specify on
the commandline with ARDUINO=<path> or on the config.mk file. stop.
then i edit the Arduino=<path> in
/home/ubuntu/arduino/config.mk and edit ARDUINO = /dev/bus/usb/001/004
which is the usb port my arduino is connected to
Then i tried typing “make” again but got a new error:
../mk/board_avr.mk:72:*** ERROR: hardware directory for arduino not found. stop.
@Jacob I have installed the ArduPilot-Arduino-1.0.3-windows ,and specified the ARDUINO=C/ArduPilot-Arduino-1.0.3-windows where it located but still got the same trouble,
Wow, interesting setup . I haven’t uploaded using either arduino or windows. There are some other threads on this forum where I give some details on how to upload to apm. I use make from the command line. The code was an experiment, and I really suggest upgrading to the newest version of ArduSub: http://ardusub.com/.
I will update the readme on my ardupilot-rov fork to indicate that it is deprecated, was experimental, and I will not be providing further updates. If you are determined to make it work, try the discussion here: Problem with running BlueROV - #5 by jwalser
