Can anyone detail the BlueRov modifications to APMrover2 code? I would like to familiarize myself with the modifications for the BlueROV. I am building a ROV with 4 laterally vector thrusters and 1 vertical thruster and will need to modify both the APM and ROS code. Maybe not the APM, but I am unsure at this point. The ROS code isn’t an issue.
I’d be happy to talk about it. The modifications made are actually incredibly minimal. We are using the APM as more of a hardware input/output layer than as an actual controller right now. If you look at our fork of the ArduPilot repo, you’ll see that there is a branch called br-ros-rov. We only made one small change to that branch, namely enabling MavLink PWM output through all available channels. (By default most of the channels are disabled).
That allows ROS and mavros to interact with everything onboard the APM, including the PWM outputs. The actual motor commands are all calculated in ROS instead of on the APM.
Another alternative is to use a different APM flavor on your Navio+. At the moment, the only thing we use the APM for is the servo commands so really any mavlink-compatible controller that understands the “set servo” (183) command should work.\
In the future, we plan on utilizing the APM’s IMU for some minor closed-loop control. We’ll be using mavlink again for this communication, so you should be future proof as long as your Navio+ code does the same.
