Ping360 shows no readings
Hi everyone. I recently got the Ping360 and have connected it using the USB configuration. I have installed the latest version of Ping Viewer and the ArduSub Companion is up to date. The device has been detected by the device manager successfully. Then I headed to the device to view the readings but I found no readings. The stepper motor was spinning as it should. Take a look at what I saw in the Ping Viewer.
Hi @majid, welcome to the forum :slight_smile:
Those readings look normal to me. Note that
I thought that was also stated on the product page, but I couldn’t find it there, so I’ll see if I can add it to make it easier for others to find :slight_smile:
Thank you @EliotBR, I dipped it in the water and it worked fine.
Hi, I’m in the same situation. This is what my ping 360 shows when it is in air, theres no readings at all. I’m using the latest version of ping viewer. Any help would be appreciated. I can hear the motor spinning as it should
