Ping Viewer Next Layout in Cockpit
I really love the addition of Ping Viewer Next, I do however find one small issue with it in Cockpit. When it is set to 360 degree scan, the buttons arrayed around the scope align nicely, when changing to a different scan sector angle it makes a pigs ear of the alignment. Examples:
360 degree sector
180 Degree sector
60 degree sector
30 degree sector
I have played with all of the variables within the cockpit ‘edit interface’ options, but alignment remains like this.
I believe you are one of the first users trying it on field, besides our internal testers :grinning_face_with_smiling_eyes:
Ping Viewer Next has actually received a major UI update that has not been pushed yet. Most if not all of those issues were solved. @patrickelectric will have more info on that!
Hi @3dMB,
Can you please go in the BlueOS extensions page and update to the latest version of Ping-Viewer 2 ?
The latest version is: 1.0.0-beta.24
I am now running 1.0.0beta26, and the new UI is far better. The still have an issue with transparency in cockpit.. Every time I open cockpit, the ping viewer next plugin is fully solid, I then change the transparency so I may have some situational awareness of that area of the camera, then when I re-open cockpit, the transparency is set to solid again.
see linked screen recording example
Great to hear! :smiley:
It seems this is a known issue - thanks for re-flagging it :slight_smile:
As a workaround it should be possible to right click the widget while in Edit Mode, and change the transparency there instead. It should be persistent after a few seconds (for Cockpit to sync the settings update).
@EliotBR his does not seem to be a workaround
The workaround idea was to use the opacity slider in the right click context menu (which exists for all widgets), not the one in the widget’s main configuration options.
I was told that was working in a testing discussion yesterday, but I’ve just confirmed it’s actually not, which @rafael.lehmkuhl also found in his pull request to fix the issue properly.
Fix should be merged in the next couple of days, and I suspect there’ll be a new beta out next week or the one after :slight_smile:
Just released v1.19.0-beta.13 with the fix. The transparency slider inside the iframe config should now be persistent.
