Ping Sonar and ROS
We have a ping sonar and we use our underwater vehicle with Robot Operating System (ROS). How can we use ping sonar on the ROS.
Best Regards,
I haven’t used ROS before, but given bluerobotics provides the ping-python and ping-cpp libraries on github, you can likely use one of them to connect with it.
In case it’s helpful, the bluerobotics companion computer uses ping360_bridge_manager.py to connect to the Ping360 on startup, and port-forward messages between it and PingViewer running on the top computer.
Check this post:
Thank you so much Patrick.
Thank you so much EliotInsight.
