Is it possible to connect PING360 Sonar directly to one of the ports in ethernet switch, using the existent JST-GH connector (internally Ping 360 was set to ethernet)?
Luis
Luis
Yes, I have done this with a different switch, but it passes the data through and can be viewed in Ping Viewer.
Hi @lbentes,
Yes, it should work fine to connect the Ping360 (in ethernet mode) to the ethernet switch - we even have a section on doing so in our Ping360 Installation Guide for the BlueROV2 ![]()
