Hi all,
I am working on an ROV build intended to operate at depths of 250m to 300m (~25–30 bar hydrostatic pressure) using a standard BlueRobotics 4" aluminum enclosure.
The Problem:
I need to pass a [power / hybrid tether] cable with an outer diameter (OD) of [X] mm into the enclosure. The jacket material is [PUR / Polyurethane].
Because the native WetLink Penetrator (WLP) system maxes out at ~9.8mm due to the M10 bulkheads, standard off-the-shelf options won’t fit.
Approaches currently considered:
Custom CNC M14/M16 Penetrator + Potting: Machining a 316 SS or anodized 6061-T6 bolt with an integrated face seal O-ring groove, then potting the cable using 3M Scotchcast 2131 or DP420.
Subsea Bulkhead Connector: Transitioning to a SubConn / Seacon MCBH micro-circular connector (requires re-tapping to 7/16-20 UNF).
External Splice / Breakout Box: Breaking the large cable into multiple smaller AWG wires outside the hull, each entering via standard WLP penetrators.
Questions for the community:
Has anyone successfully modified a BlueRobotics aluminum end cap with an M14/M16 or 7/16"-20 port without compromising structural integrity at 300m?
For cables with PUR jackets at 30 bar, what surface preparation and potting compound have proven most reliable against water ingress along the jacket interface?
Are there any proven off-the-shelf compression glands or feedthroughs designed for 10–15mm cables at this pressure rating?
Looking forward to your insights and real-world recommendations!
