Hi!
I am attempting to connect two of the blue robotics low-light USB cameras to a Raspberry Pi 4. Both of the cameras are showing up in blueos with previews but when I go into qgroundcontrol I’m not able to add a device using the video tab that is there in the documentation. Has anyone else ran into this issue an if so how did you fix it?
Hi @Tenzin -
Unfortunately, QGround Control does not support multiple video streams!
This is possible to accomplish with our in-development alternative, Cockpit. It’s compeltely open-source, and can be installed as an extension from the BlueOS Extension Manager. Adding multiple, picture-in-picture video streams is easy in this way!
