Hi BlueRobotics,
I’m a big fan of your housing for the MS5837-30BA pressure sensor. The thing is that I’m currently working on an application where I need to measure atmospheric pressure (rather than water depth). Therefore I would instead like to use the MS5837-02BA while still having the smart housing of the Bar30. Is that something you would consider selling? From what I can see, the 30BA and 02BA has the same physical dimensions, so it should be a simple replacement.
Best Regards,
Andreas
