MS5837 30 Bar Malfunction?
I am running into a situation with the MS5837 30 bar sensor where the depth, pressure, and temp does not seem to work. The pressure is always 0, the depth is always -33.99, and the temp is alway 20.
I have tried three different sensors (same model). Once I had the same issue. The other time I got wonky readouts.
This is the wiring:
The sensor is connected though I2C with a Sparkfun Mux board to allow other I2C connections from other sensors. VIN is 3.3V.
This is the code:
#include <Wire.h>
#include <SparkFun_I2C_Mux_Arduino_Library.h> //Click here to get the library: http://librarymanager/All#SparkFun_I2C_Mux
#include "MS5837.h"
#include <DFRobot_OxygenSensor.h>
#include <SparkFun_SCD4x_Arduino_Library.h>
#include <SparkFunBME280.h>
#define COLLECT_NUMBER 10
#define Oxygen_IICAddress ADDRESS_3
MS5837 sensor;
QWIICMUX myMux;
DFRobot_OxygenSensor oxygen;
SCD4x mySensorSCD;
BME280 mySensorBME;
const int OXYGEN = 2;
const int NITROGEN = 3;
const int BLEED = 4;
float water_level_pressure;
float uw_water_level_pressure;
void setup() {
  Serial.begin(115200);
  Serial.println();
  Serial.println("Qwiic Mux Shield Read Example");
  Wire.begin();
  if (myMux.begin() == false)
    Serial.println("Mux not detected. Freezing...");
    while (1)
  Serial.println("Mux detected");
  // Initialize SCD4x sensor
  while (!mySensorSCD.begin()) {
    Serial.println("SCD4x sensor initialization failed.");
    delay(1000);
  while (!oxygen.begin(Oxygen_IICAddress)) {
    Serial.println("Oxygen sensor initialization failed.");
    delay(1000);
  // Initialize BME280 sensor
  while (!mySensorBME.beginI2C()) {
    Serial.println("BME280 sensor initialization failed.");
    delay(1000);
  sensor.setModel(MS5837::MS5837_30BA);
  sensor.setFluidDensity(997); // kg/m^3 (freshwater, 1029 for seawater)
  pinMode(OXYGEN, OUTPUT);
  pinMode(NITROGEN, OUTPUT);
  pinMode(BLEED, OUTPUT);
  // Initially turn off all relays
  digitalWrite(OXYGEN, LOW);
  digitalWrite(NITROGEN, LOW);
  digitalWrite(BLEED, LOW);
  delay(100); // wait for co2 levels to stabilize
  water_level_pressure = mySensorBME.readFloatPressure() / 100.0; // Read circuit pressure and convert pressure to hPa
  uw_water_level_pressure = sensor.pressure(); // mbar
  uw_water_level_pressure = uw_water_level_pressure * 100; // convert to hPa
void loop()
  myMux.setPort(0); // underwater sensor
  sensor.read();
float uw_pressure = sensor.pressure(); // mbar
  uw_pressure = uw_pressure * 100; // convert to hPa
  float uw_temp = sensor.temperature(); // celsius
  float uw_depth = sensor.depth(); // meters
  uw_depth = uw_depth * 3.28084; // convert to feet
  float o2 = oxygen.getOxygenData(COLLECT_NUMBER); // percent
  int co2 = mySensorSCD.getCO2(); // ppm
  float temp = mySensorBME.readTempC(); // celsius
  float humidity = mySensorBME.readFloatHumidity(); // RH (percent)
  float pressure = mySensorBME.readFloatPressure() / 100.0; // Read circuit pressure and convert pressure to hPa
  float ata = pressure / water_level_pressure;
  float uw_ata = uw_pressure / uw_water_level_pressure;
  float ppo2 = (o2 / 100) * (pressure * 0.75006375541921); // pressure in mmhg
  float ppco2 = (co2 / 1000000) * (pressure * 0.75006375541921); // pressure in mmhg
  int bleed_time = 0;
  int o2_time = 0;
  int n2_time = 0;
Serial.print("UW pressure: ");
  Serial.print(uw_pressure); // 0
  Serial.print(",");
  Serial.print("UW temp: ");
  Serial.print(uw_temp); // 1
  Serial.print(",");
  Serial.print("UW depth: ");
  Serial.print(uw_depth); // 2
  Serial.print(",");
  Serial.print("O2: ");
  Serial.print(o2); // 3
  Serial.print(",");
  Serial.print("CO2: ");
  Serial.print(co2); // 4
  Serial.print(",");
  Serial.print("Temp: ");
  Serial.print(temp); // 5
  Serial.print(",");
  Serial.print("Humidity: ");
  Serial.print(humidity); // 6
  Serial.print(",");
  Serial.print("Pressure: ");
  Serial.print(pressure); // 7
  Serial.print(",");
  Serial.print("O2 time: ");
  Serial.print(o2_time); // 8
  Serial.print(",");
  Serial.print("N2 time: ");
  Serial.print(n2_time); // 9
  Serial.print(",");
  Serial.print("Bleed time: ");
  Serial.print(bleed_time); // 10
  Serial.print(",");
  Serial.print("UW ata: ");
  Serial.print(uw_ata); // 11
  Serial.print(",");
  Serial.print("ata: ");
  Serial.print(ata); // 12
  Serial.print(",");
  Serial.print("PPO2: ");
  Serial.print(ppo2); // 13
  Serial.print(",");
  Serial.print("PPCO2: ");
  Serial.print(ppco2); // 14
  Serial.print("\n\n");
  delay(2500);
Readout over serial is:
UW pressure: 0.00,UW temp: 20.00,UW depth: -33.99,O2: 20.07,CO2: 527,Temp: 26.34,Humidity: 62.58,Pressure: 1001.22,O2 time: 0,N2 time: 0,Bleed time: 0,UW ata: nan,ata: 1.04,PPO2: 150.69,PPCO2: 0.00
My soldering skills suck, so maybe that’s the reason? Did I fry the sensor?
Hi @dwcs, welcome to the Blue Robotics forum :slight_smile:
That’s not an issue I’ve come across before, but it’s also hard to provide much advice for a board/package we haven’t manufactured and don’t have experience with. Contacting the manufacturer of the actual sensor is more likely to be helpful on that front (we just sell a packaged version of it, and provide some libraries to help people integrate that).
As a general principle I would recommend testing any new device/integration independently first, and preferably without permanent fixture or conditions that could cause damage/interference, just to make sure it’s working as expected. That also applies to avoiding extra hardware attached to the same communication and/or power lines, and doing the initial software testing with only code for the device being tested.
Electronics (and sensors in particular) are sensitive to a variety of different external factors. The sensor datasheet provides some maximum ratings from the manufacturer, for things like temperature, pressure, and electrostatic discharge, and mentions this soldering guidance document as well, although that’s largely focused on soldering the sensor itself to a board, rather than soldering wires to that board.
Unchanging values from a sensor in variable conditions would generally indicate some kind of hardware failure, but the specific cause may be tricky to determine :man_shrugging:
