Mavlink camera excessive resources?
Using blueos 1.2.2 & sub 1.2.1
Mavlink camera is using over 50% cpu and occasionally jumps to 80%+
Anyway of reducing this?
Thanks.
Resolved, turned the telemetry rate down to 8Hz.
Hi @Teggles,
I did ask about this at the time and was meaning to get back to you, but the internal response was that
I don’t think the MAVLink telemetry rate should have a significant effect on the camera manager, so I’ll ask whether we can reduce that dependency somehow.
Thanks for that Eliot. I am not à coder but everything is working fine so I will not tempt fate!
The only issue I have is ping viewer stops the joystick working! Come out of ping viewer and all is fine. I must have a conflict somewhere. I will update pingviewer and see if it is an issue with BlueOS 2.2 and an old version of pingviewer I am using.
