M500 Motor Parameters — Technical Data for Level-Wind Project with T500 Thrusters
Hi everyone,
I’m currently working on a level-wind system and using M500 motors. However, I couldn’t find complete technical data for the M500 motor — I only have access to the M200 documentation.
I’d like to know if anyone has the following parameters for the M500, or could point me to where I can find them:
  • Maximum torque
  • RPM at different voltages (e.g., 16 V, 24 V)
  • Current draw at maximum load
  • Efficiency at different load ranges (low, medium, maximum)
Thanks in advance for any help or documentation you can share!
Hi @DanBRS, welcome to the forum :slight_smile:
We don’t yet sell a motor-only variant of our T500 Thruster, so the M500 does not currently exist as a product.
Assuming you mean you’re using modified T500s then the available specifications are in the technical details section on the product page. Note that as it’s not sold as a general purpose motor, it is also not directly specified as one (so we don’t currently provide a stall torque value, and the RPM measurements are assuming the load of water resistance to the included propeller, which may not match your winch load).
Noting that the M500 has now been released :slight_smile:
