Full caracteristics of the T100 and T200
is it possible to have all the caracteristics of the thrusters motors ?
I’m working on a simulation on scilab and would need a few parameters :
  • Statoric resistance
  • Statoric inductance
    -Mutual inductance
    -number of pair of poles of the rotor
    -moment of inertia of the rotor
    -vicious friction coefficient
    -constant flux of the magnet
Thank you much for your response
Best regards
Hi @ManuH Regrettably, we don’t have any more information than what is on our Technical Details tab right now: https://bluerobotics.com/store/thrusters/t100-t200-thrusters/t200-thruster/#tab-technical-details
hi kevin,
thank you for answering.
Is it because you don’t want to post them publicly ? Or just don’t know?
Can I contact your manufacturer ?
thank you
We are the manufacturer.
We haven’t spend the time to attempt to figure out these values as we continue to work on new hardware. The T100 and T200 are also incrementally changing so specifications may be different from year to year as we make changes and revisions.
I recommend looking into other academic papers to see if anyone has found the specifications you are looking for. If they have, they have not been shared with us.
I understand.
I could share my work on scilab when it’s finished if you want.
I also tried to model it with a few SysML diagrams but they are in french, if you’re interested.
Have a good day
Hey @ManuH,
I’ve spent some time characterizing the T200 thrusters. I’m using a bit of wimpy power supply, so I ended up limiting the motor to a current of 4A @ 16V for my testing. Below are the values of some of the parameter’s I’ve been able to find.
Stator Resistance (R_s) = 0.1 ohm
Stator Inductance (L_s) = 0.03 mH
Back EMF Constant (B-EMF) = 1.687 Vrms/kRPM
Moment of Inertia = 5.85 uN*m*s^2
Friction Coefficient = 0.42 uN*m*s
Number of poles = 14 (7 pole pairs)
I hope this helps.
